Moto g power 64gb
yumatrpt
I need to find out if I bring an unlocked Moto g power with 64gb if it will work on Visible. I know that the 32gb is available.
CJ
Intermediate
It should, to be sure, go here: Check If Your Phone Is Compatible | Visible
If you don't have the physical phone now to do the check, I would only buy the phone with a rock solid return policy, on the off chance it won't work.
