Showing results forΒ
Search instead forΒ
Did you mean:Β
2.4 GHz or 5 GHz for Mobile Hotspot
VariableGemini
I was wondering which band would be better for the mobile hotspot considering we only get 5 Mbps speeds. I understand 5G is faster but has less signal range, while 2G is slower and has a wider signal range. I was curious if using 5G would be counterintuitive because we can only get 5 Mbps speeds anyways.
6 REPLIES 6
Moxie
Superuser Founder
Superuser Founder
Talking about 2 separate things......
1. In MOST cases 5ghz is faster/better.
2. Right now LTE is much more reliable and consistent then 5g. I set my phone to LTE only, works great!
Best!
With this being said, do you think that 5GHz will be less congestion than 2.4 GHz in a case of being surrounded by many other devices in a crowded building?
Airwolf
Superuser Founder
Superuser Founder
Have you tried running a speed test on the tethered device to see what speeds you are actually getting?  If you are getting the full 5Mbps then I think going to 5G would not have any gains in this case.
I have and they both come back very similarly. I am just wondering if the network would be less congested on 5GHz compared to 2.4 GHz.
When you are talking 5Ghz WIFI it is almost always better, particularly when it comes to hot spot as you are more likely to be in very close proximity to the access point/phone while in use. Make sense?
It absolutely makes sense, I seriously appreciate the swift response!
