Verizon JetPack to Visible - will it work?
Norseman
darrenbeau1
As long as device is not carrier locked and you can configure the apn settings it should work on visible. It would most likely get throttled to 5mbps as a wifi hotspot for non mobile data. There are theories to bypass this but that is in effect lying to your carrier and not recommend.
