09-15-2022 08:28 AM - edited 09-15-2022 11:48 AM
Make sure to restart phone after adding these to your phone.
Go to Settings, Connections, Mobile Networks, and the Access Point Names.
Make this the APN default APN
Name
Visible internet
APN
vzwinternet
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://mms.vtext.com/servlets/mms
Multimedia message proxy
Not set
Multimedia message port
Not set
MCC
311
MNC
480
Authentication type
Not set
APN type
default,dun,supl
APN protocol
IPV4/IPv6
APN roaming protocol
IPV4/IPv6
Turn APN on/off APN
turned on
Bearer
HSPA, GPRS, EDGE, EHRPD, UMTS, LTE, HSPAP, IWLAN, HSDPA, NR. HSUPA
Mobile virtual network operator type
GID
Mobile virtual network operator value
BAE2000000000000
Name
visible Fota
APN
vzwadmin
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
Not set
Not set
Not set
MCC
311
MNC
480
Authentication type
Not set
APN type
fota
APN protocol
IPv4/IPv6
IPv4/IPv6
Turn APN on/off APN
turned on
Bearer
Unspecified
GID
BAE2000000000000
Name
visible cbs
APN
VZWAPP
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
Not set
Not set
MCC
311
MNC
480
Authentication type
Not set
APN type
cbs,mms
APN protocol
IPv4/IPv6
IPv4/IPv6
Turn APN on/off APN
turned on
Bearer
Unspecified
GID
BAE2000000000000
2 weeks ago
Had the same issue after switching to Visible+ via eSIM—APN didn’t load, and I wasn’t about to go through another eSIM re-download nightmare. Manually entering the APNs fixed it for me. It’s a lot like what happened with where manual setup was the only real fix.
