Can’t join party Reddit_Upvote
Prcheek
When I go to join this group via visible.com/p/Reddit_Upvote I click the join button then it redirects me to the main party screen.
if I go to the main party screen and select this group, I get an “internal server” error in app and a “something went wrong. we are trying hard to fix it” error in both safari, brave and chrome.
how do I go about joining? Support can’t help. They say that as soon as I click to join, it shows me leaving the group.
Hey there! Thanks for raising this concern. Our Care team might be able to manually add you to the party, so I would recommend reaching back out to them. You can reach out by chatting on our site, tweeting @visiblecare or sending a DM to @Visible on Facebook.
