Question about swappable phones
Pugmama
I'm thinking about switching to Visible and am trying to find out more info on the 2 phones to swap for. Does the Visible midnight or the Moto pure g have 5g?  Do they have sd card slots?
Thanks for your help.
MJM15
Neither has 5G capability but they each have one microSD slot.
https://www.visible.com/visible-midnight-user-guide
https://www.motorola.com/us/smartphones-moto-g-pure/p?skuId=648
Check out Visible's deals page if you really want a phone with 5G. New customers have several reward options to choose from depending on the phone you buy (up to $200 gift card + your choice of earbuds). Also, many of the android phones are relatively cheap without a "deal" and can be financed if you want.
MJM15
Referral_3m3RMt
There are a few budget 5G phones.
The TCL 20 A 5G for $192 with a $50 gift card
https://www.visible.com/shop/smartphones/tcl-20-a-5g
and the
Moto One 5G UW ACE for $288 with a $100 gift card and pixel buds
https://www.visible.com/shop/smartphones/motorola-one-5g-uw-ace
I'd pick the Moto Ace personally.  Best price to performance and with the promos is about the same price.
There is also the Blade X1 5G but it is more expensive and doesn't offer much more over the moto in my opinion.
Both the midnight and the Pure do include micro sd slots.  5g isn't all that necessary.  It doesn't make much difference unless you are right in the middle of a big city.  Either of these swap phones are good.
