12-06-2021 08:08 AM - last edited on 12-07-2021 07:27 AM by LS-VisibleMod
WARNING: Visible's Verizon service does not function fully in Texas. Mobile Hotspot features do not work in Texas. When using Visible in Texas, attempting to use the alleged mobile hotspot feature, a warning message appears:
"Your order could not be processed To use Mobile Hotspot, you will need to subscribe to the Mobile Hotspot service. To subscribe to the Mobile Hotspot call customer care at (800) 922-0204"
Calling that number results in the typical garbage level abysmal service impotence.
12-08-2021 10:29 AM
Im in texas and mine worked last month while going to Texas renaissance festival kids used it the whole 3 hrs drive there. Now that is if the data is fast enough to use which has been my biggest issue. When you can't even stream music because the speed is so slow.
