$25 plan - Visible Community
$25 plan
Nana15
I would like to know if the Google 9a will be compatible with the $25 plan. Thank you.
Ace II
It likely will be once it is released, it may take some time for Visible to receive the IMEI numbers for released phones to update their database. Not sure if they get these numbers prior to release. Some newly released phones have taken a week or two after release before they would pass the IMEI checker at Visible. If you buy it from Visible it should be in the system and compatible the day they release it for sale.
