11-21-2024 07:38 AM
Quick question, I would like to switch my service from Verizon to Visible today. I bought a new iphone from Apple, but have not yet activated it. Should I activate the phone with verizon first, or port my number and then activate it with Visible?
Thanks!
11-21-2024 10:18 AM
You can do either as far as activating it. You could make it easy and just activate it on Visible, you will be assigned a temp number then you could port it in.
