01-17-2023 12:11 PM
Removed SIM card and restarted phone. Cannot make calls. Upper left screen shows "No SIM" and "SOS Only"
01-17-2023 03:34 PM
Hello,
It sounds like either the SIM card is not functioning, or your sim tray slot is no longer working. Have you tried using eSim?
01-18-2023 05:22 PM
Okay, you are removing the SIM and restarting the phone with no SIM? Or are you trying to activate an eSIM instead of a physical SIM?
