โ08-02-2023 09:36 AM
I want to take advantage of the Visible+ plus plan on my 14 pro, what are the best settings to optimize connectivity to Visible's network.
Any suggestions?
โ08-03-2023 08:00 AM - edited โ08-03-2023 08:02 AM
I have Visible+ and an iPhone SE 2022
At Settings - Cellular - Cellular Data Options
Data Roaming is On
Voice & Data 5G Auto
Data Mode Standard
Limit IP Tracking On
Wi-Fi Calling is Off
We have a good Verizon signal at our home and through testing the Cellular voice is a little better quality than our Comcast 75/10 cable connection using WiFi calling.
The best cellular data speed that Iโve gotten at a Verizon tower is 437 MB down and 157 MB up using the Speedtest.net app
For whatever reason, my SE 2022 only shows 5G in Atlanta and not 5G UW even though this phone supports the UW C band.
Data Roaming is On
Data Mode Standard
