- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
โ07-21-2021 07:34 AM
So my iPhone X was bought at an Apple Store and I've only used Straight Talk/Tracfone since then.
From what I can remember at the Apple store I had to choose a carrier even to buy the phone so I think I just said AT&T not really knowing at the time if I was gonna go with ST or not.
I just want to use this phone as a hotspot for my laptop while travelling.
As I think I understand it, currently, I can with Visible at 5mps speed with one tethered device.
Just making sure because I tried this with T-Mobile once and it didn't allow the phones hotspot fuction to work.
Thanks in advance for any advice!!๐
- Labels:
phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ07-21-2021 08:24 AM
Welcome aboard.
A couple of notes:
-You will want to run your iPhone through the compatibility checker here: https://www.visible.com/shop/compatibility
-I believe Apple devices may not be subject to the one connection limit.
-If you have problems setting up the hotspot, I would refer to these two articles:
https://support.apple.com/en-us/HT204023
And
https://support.apple.com/en-us/HT203302
When you join Visible, I would appreciate it if you would use my referral info:
Check out this page: https://www.visible.com/get/36mt7h, it has all the info you need to know about joining Visible. When you use my friend code, 36mt7h, youโll get your first month of service for only $5!
We both will get a month of service for only $5.
-Plan to join a Party Pay party, so then second month and afterwards your service will cost $25/month. Join a large party, so you don't have to worry if one person drops out your service will be more expensive.
-If you want to save a few more bucks, sign up for Visible via the Rakiten link. If you are a new member to Rakuten, with your first qualifying purchase you will earn a $30 rebate. And by using the Visible link on Rakuten.com to sign up for Visible, that will generate another $15 rebate.
Not a member of Rakuten? I would appreciate if you would use my referral link: https://www.rakuten.com/r/RAKUTE3083?eeid=28187
If my reply helped, please give some kudos and approve my answer. Have a nice day.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ07-21-2021 09:24 AM
will do. ๐
have your referral link copied.
I'm in Thailand til 3rd week September but def joining soon as soon as I get stateside.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Welcome aboard.
A couple of notes:
And
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
will do. ๐
