Budapest to Bucharest - Visible Community
Suzimatt
I’m going on a river cruise from Budapest to Bucharest. What must I do to be able to send and receive texts while I’m gone?
There are lots of variables/ missing information in your question.
1) What plan do you use? Visible base plan or Visible+ plan.
If Visible+ plan have you used your one complimentary day of global pass? If yes have you enabled global pass?
If it is Visible base plan then have you enabled global pass?
2) Will you have internet on the cruise that you have? If there is Wi-Fi/ Internet available on the cruise boat. If you had enabled WIFI calling feature earlier (in USA) then you can use visible number to call and text US numbers.
Thanks. I have the basic Visible plan, but I got an offer via email to upgrade to Visible plus. Unfortunately, when I try to do it, I get a message saying the code is not valid or expired, even though the message says the code is to be used before August 8. I’ve tried multiple times and I can’t make it work. To answer your other question, I have enabled global pass. I also have Wi-Fi calling enabled. Will this be sufficient for me to use my phone ? Thanks!
