CNAM Issue
M0710NM4N
So I just signed up for Visible and already out of the gate I'm not super thrilled. Neighbor has ST and their speeds are more than double mine. I'm lucky to be pushing 70 - 80 MB and their getting a little over 200! Also I call my mom and it's still showing up as Wireless Caller and that's one of the reasons I left XFi! Not sure if it's because I just got the service and if maybe it takes X amount of time to work or if something isn't working correctly. Also ran SpeedTest and noticed I get NO upload speed at all... is that normal for Visible, because I've always gotten an upload speed even if very slow with past providers.
12 REPLIES 12
Intermediate III
What device do you use with Visible?
I didnt have caller ID issue. This seems to be new.
I have the S22 Ultra
What service does your neighbor have, and the s22 should have very fast downloads
They have Straight Talk.
Straight talk internet is faster then visible I sew costomers from straight talk getting 500 Mbps
M0710NM4N
Can anyone else confirm if they're outgoing Caller ID shows your name or does it show Wireless Caller? When I first signed up for Visible I assumed since they were part of Verizon that my actual name would show up like it should with most of the bigger providers like Verizon, AT&T and T-Mobile. But I contacted support a little while ago and they tell me that Wireless Caller is what should be seen as Visible doesn't offer advanced caller-id features.
Odd thing is that when I first noticed this supposed issue, I did a Google and within the Visible forums is another thread about this very issue and others said they got it fixed and their requested name was then showing and even included a CNAM online tool to check. So how is they got theirs fixed yet I'm being told they never had this feature?
Usually only possible customers could set the caller ID no prepaid companies offer caller ID, but if you port your number from a big Carrier and you had your caller ID setup, then it stays the caller ID and it doesn't change and even you cancel your account and someone else gets your number it will show your name
Well considering visible is part of Verizon how much bigger of a company can you get?
well visible is a prepaid brand from Verizon and like every prepaid company that don't offer caller ID
No this is not the case
Actually this is where you are wrong.
I've had my caller id changed for metro, straight talk & a few others. Including tmobile, verizon and att.
What is true is not all offer to do it although they can.
Ya mine does show wireless caller
