Calls Dropping In St. Louis!
joshwatersdj
This has started happening over the past few weeks and is getting old.  They even drop on Wifi calling.  I live in a populated area, 3-4 bars of signal in my home with great data speeds.  Why the calling issue?  I have already spoke with tech support, had my SIM re-provisioned, the whole deal.  Please address this, the internet shows I am not the only one, it is country-wide.
Please kudo this feedback, so Visible takes action on them.
https://community.visible.com/t5/Feedback/Call-drop-Call-failure-at-Visible/idi-p/22087
