01-27-2025 06:12 PM
I have a Verizon hotspot/mifi that I was using for work. My work has given me the device and cancelled the plan. I would like to port it over to Visible for just a data plan. Do you offer an option for that?
01-28-2025 12:07 AM
It goes against Visible's terms and conditions to use a SIM any in anything other than a smartphone. If you have Verizon home internet you can get a $5 off if you get the base plan or $10 off for the plus plan.
