Can't receive Incoming calls
rador30
Still having issues similar to what other users have complained. I ported into Visible physical sim from T-Mobile and have not been receiving any incoming calls since.
Tried troubleshooting with the customer rep but he was unable to find a solution. This seems like a network issue affecting far too many users. Visible Mods please raise it to your leadership.
4 REPLIES 4
mdistefano
I am having the same problem on iPhone8
mdistefano
same problem on iPhone8.  Converted Sunday night and still no incoming calls.  I get a message from my old carrier that the number has been changed or is no longer available.  Pretty bad if you ask me!!!
zllibengood
Same issue here. Using Google Pixel 4a5g. Came from ST with physical sim to here using e sim
zllibengood
Same issue here. I'm using a Google Pixel 4a5g. Came from ST using a physical SIM to here using an eSIM
