Cellular settings went back to TMobile after I reset network settings on iPhone
Spoonie
I reset my network settings as advised by Apple so that I could fix a sync problem to iCloud that I was having. That knocked me off the Visible network and now shows in my iPhone settings that my cell settings are for T-Mobile, which was the carrier I had before I ported over to Visible. How do I get my IPhone settings back to Visible so I can use the phone?
I am not an Apple user but a suggestion is to make sure and delete the T-Mobile eSIM if it is still showing if you no longer are using them. Another thing I read about is make sure Visible is set to primary. Again I know nothing about Apple phones, these are just things I frequently read about on Visible's reddit page. If you are on Reddit try posting this question on their, there are a lot more visitors to that page versus the handful, if that even, that visit here.
