3 weeks ago
I’m contemplating buying the Ikko Mind One. Links below for reference. However, I’m not sure if it will be compatible with visible based on what I researched. It has the right bands needed, but I know visible can be strict with their IMEI compatibility. Is there anyone able to tell me if the phone will work with visible or not?
3 weeks ago
Hi @Sammoodie7 -
If the bands are supported, you could likely activate a physical SIM with another known working phone (use that IMEI), get it activated, and then physically move your SIM card over to the Ikko Mind One (since it has a physical SIM card slot).
The only questionable part would be features such as Visual Voicemail as that might not work. I would expect calling, texting, and data to work, though.
