Data not working on Galaxy S10E
Madden2218
I have tried over and over to resolve this issue can anyone help me. Phone and text work but data will not have factory reset. did not help.
GreenSub
I think you need to change the APN settings.
I jotted down this note 5 months ago, but you might want to do a search for updated settings if this doesnโ€™t work. Good luck
โ€”โ€”-
APN name: Verizon 2
APN: vzwinternet
MMS port: 80
MCC: 311
MNC: 480
Apn protocol: iPv4/iPv6
Apn roaming protocol: iPv4/iPv6
APN type: default,supl,mms
Leave all other fields blank, and save this configuration.
Restart the phone
Not sure if the new plans allow but I am still on the old plan and the APN settings are locked on my phone, but it's a Motorola. Not sure if it would be any different on other android phone or not. Might be different with a new SIM on one of the new plans.
