05-23-2025 09:03 AM
Hello,
I started w/Visible to see how well it would work in our "summer" location as T-Mobile gets spotty service.
I normally use Android only devices but had an older (11 series) iphone and am currently using the new visible sim in it. Short story is it fluctuates between 1 and 3 bars on the phone with the same fluctuation is service... 3=barely useable 1=me walking the lot trying to find 3 bars.
My daily driver phone is a Samsung s25 series phone thru TMO... wondering if there would be any consequence in short term swapping Vis sim into it to see if I get better signal? Would it screw up my device swapping Vis in and out then TMO back in? Or screw up service w/TMO?
Thanks for any advice available... the goal here is to confirm staying w/VIS on a newer device is a viable solution to no connection in our location.
Thanks,
Capn
05-23-2025 09:19 AM
I have never messed with two SIM cards but I have moved my pSIM for phone to phone before. The same card has moved from a Motorola into another Motorola and then recently back and forth a few times between my current S24 and the backup 2 year old Motorola a few times, most recently a month ago and I have had no issues with moving the card. It should be no different with either the T-Mobile or the Visible SIM card. Pop out one card and pop the other one in and service should resume.
