Disable Voicemail - Visible Community
Disable Voicemail
phone12
Hi,
How can I disable my voicemail? Using visible wireless on an iPhone and would like voicemail to be permanently deactivated. Thanks.
rjniles
Contact Visible chat and make this request.
jmaz103
You can try holding down the โ€˜1โ€™ key on your phone app to bring up your voicemail settings. If that doesnโ€™t work then contact Visible customer service. Ask them to turn off your voicemail.
