โ11-19-2024 06:53 PM
I've been searching for a while and a lot of plans will slow you to 3G speeds after using 20gb or 40gb of 4G speeds even with UNLIMITED data. At that point it feels worthless to pay for unlimited when we're .. limited. I'm going to buy a phone soon that supports 5G and will likely switch as my wife and I have jobs that require us to be in places with not great connection occasionally and its hard to be on calls and or watch tiktoks when we're a week or month away from home at a time. I can't find anything that says whether or not Visible slows it down or doesn't. Anyone have any idea ? I would likely pay for their $275 yearly plan (for both phones) if it shows they don't slow us down to 3G after 10 - 40gb
โ11-20-2024 02:00 PM
Visible does not throttle or slow you down after a certain amount of data used, it is truly unlimited including hotspot. The Plus plan does get you 50GB of premium or priority data while on 4G LTE and 5G(5GUW doesn't count towards this limit) then you would be deprioritized. The base plan is deprioritized data speeds would depend on traffic/congestion in your area. I am on the base plan myself and I do see speeds get super slow to almost unusable at times but usually that is for short periods.
You should try it first on the trial or a month or two before committing to a full year because once you pay for the year and you have issue Visible does not refund for unused months. This is because it is prepaid service and basically a contract for the period you pay whether it is by the month or by the year.
Hope this answers your question.
โ07-11-2025 01:01 PM
they throttle you, then deny it
