Does the Unlocked Samsung Galaxy A16 work with Visible?
Wytmagic
I am looking for a new phone. Does the unlocked Samsung Galaxy A16      5G work with Visible? It is in the low price range but has a guaranteed six-full update cycles, which is awesome since I do not change phones often. Also, it has SIM card memory expansion.
It should. You would have to check the compatibility checker to make sure it passes so you can get a SIM card or eSIM if it is capable. You can check the phone by clicking the following link.
