โ09-05-2025 09:08 AM
I have noticed that others with the same Pixel 8 have more spam options in their phone app settings than I do. Does Visible remove some of the options in the Google phone app settings? I want to send all spam calls to voice mail.
โ09-05-2025 11:15 AM - edited โ09-05-2025 11:17 AM
Visible has a spam filter, if you go into your account and click on privacy and security there is settings you can go into and change to do that. Doesn't seem to be to effective as I still get spam calls or calls that say potential spam and they get through.
As for your Pixel, I have the 9A and with Google Phone and it doesn't have a way to send all spam calls calls to voicemail. It doesn't even see to have a spam filter anymore since the last update. The toggle for it now says caller and spam ID. There is an option called "call screen", I haven't used it so not sure how it works.
Also, the Google phone app has a new look and update so not sure if you are on that or not. I think call screen was on the last version but not sure since I never use it.
โ09-08-2025 06:32 AM
Thanks for the tip, I didn't see the spam settings in the visible app. My settings were set pretty low.
