Flagging
sarnac
what, if any, is the process for reporting or flagging comments, replies that may violate terms and agreement?
RyanBlakeIT
Hi @sarnac - If you click on the little downward carat icon to the right of the post's author, you should see an option to "Report inappropriate content."  Hope this helps.
