β08-12-2022 05:19 AM
β08-12-2022 08:11 AM
Once you hit the activation button the The process of porting your number to visible starts. If you want your number transferred instantly you could contact your previous Carrier and tell them to release your phone number if all the information you entered is correct they're gonna release it and it's gonna be come visible right away.
β08-17-2022 05:39 AM
You can also reach out to your current provider and ask if they see any porting activity on your account. Although, be careful that they do not manually cancel your service, you will want the porting process to automatically cancel the service.
β08-17-2022 06:25 AM
99% of companies do cancel your service after you purt out your number and usually you don't have to call them to turn off auto refill
