How do I keep my AT&T and have a Visible # on the same phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
โ06-29-2024 06:48 AM
I want to have two numbers on my phone: Visible and AT&T #. They're sending me a Sim card that I don't want. Please help or attach a link to a message board where this was answered.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ06-30-2024 12:31 PM
Hi, a few things. 1 what is the phone you are trying to use? Lets start there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ07-08-2024 10:02 PM
We need a lot more details to help. I'm assuming you have two numbers. One from Visible, one from AT&T, correct? Or are you not a Visible customer yet? We need to know what type of SIM (physical or electronic) your current number is using, and which carrier its on. What device are you using? We need to know if it is 1 SIM only, dual physical SIM, dual eSIM, or 1 physical and 1 eSIM.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ07-14-2024 09:16 AM
Visible supports esim. So if you have a compatible iPhone then you shall have 2 numbers on the same device.
