07-31-2022 02:42 PM
Wondering how coverage is in Nebraska. We have family there and need good coverage when we're visiting.
08-01-2022 05:53 AM
Since Visible works off the Verizon network, I would check with family you know there. If they are on the Verizon network that should be a good indication of coverage.
Otherwise you can probably check out the Verizon coverage maps, although since it is a marketing map, not sure if it will give an indication to quality of service.
