Huawei - Visible Community
Huawei
Lety
I really want a Huawei phone p30 but before spent the money on it, I need to know if will work with Visible, the problem is I can't check the IMEI because I don't have it.
Please any help I will appreciate it.
Ace II
Only way to check it's compatibility is with the IMEI number. I looked up that phone and it appears to be from 2019 which most likely won't work on the Visible network. I would suggest a newer unlocked Samsung or Pixel(6a or newer). If Motorola it likely isn't going to pass the IMEI checker unless you buy it from Visible.
If you are dead set on that phone you would likely need to find another carrier but you will most likely still need the IMEI number for just about any carrier you are looking at moving to.
