03-15-2025 09:50 AM - edited 03-15-2025 04:37 PM
I was on Verizon for a year with my current iPhone 14s and had good cell service at my home which is also a home business. While Visible uses Verizon services, since switching to Visible, calls are frequently dropped from my home office with the same phone and I only have 1 bar on cell service. I read somewhere that Visible data speed availability may have different usage thresholds than Verizon but nothing about cell coverage quality.
03-15-2025 06:31 PM
The cell signal would be the same provided there are Verizon cell towers in your area. Let me explain, this information is from what I have read. When you were on Verizon you may have been roaming on another networks towers(AT&T or T-Mobile) if there isn't a Verizon tower close by. Verizon has roaming agreements with the other big two and Visible doesn't have the same roaming agreements as Verizon does. This could be the only thing I could think of that would cause a poor signal versus Verizon.
There are steps you can try, not an iPhone user but somewhere in you settings should be an option to reset network settings(I don't mean a factory reset) and see if the signal improves. It should try searching for other towers/bands besides the ones you are on. If your network settings has a roaming toggle make sure it is on. If Visible has a roaming agreement with the other carriers in your area I believe this needs to be on to get what is called domestic roaming. I don't know if contacting customer service and explain this signal issue if they can fix anything or provision the SIM but could be worth a shot.
When it comes to data speeds a low signal strength can have an affect on speeds and cause that to be slower versus being closer to a tower with a good signal. As for data if you are on the base plan you are deprioritized and speeds will be slow when there is a lot of traffic on the towers and it is congested but this wouldn't matter as far as making a call.
I am not sure what else you can try other to check out the Visible coverage map and check what you area has for coverage. https://www.visible.com/plans/coverage
03-15-2025 06:31 PM
