I can't do voice calls and send texts.
pandawcb
I can't do voice calls and send texts. The Internet and all services are working fine.
5 REPLIES 5
Victor
So what did you end up doing because I have the same problem
The main issue - is not fully downloaded e-sim.
I spent a few days in the line the support. We tried to reset and re-download the e-sim a few times. Maybe something was being done on the Visible side, but nothing did not help. It's a dead end.
I'm waiting for the last mail from Visible. I don't believe that it can help. Looks like it can't to works for me.
TheBudster
My wife is now having this problem too!!
Check my answer to the previous mate.
pandawcb
The issue was fixed! The service is working fine. ๐Ÿ˜€
