I lost my phone and need to order a sim card for my old iPhone 6S
JHunter
VisibleRocks
If you have web access, you can order the SIM though your account, but for certain results, I'd suggest that you do a chat with customer support.  Get Help Online, In App, Or Through Social | Visible
I have tried the "Chat" bot, no help! I tried the Social media links, no response! I went into my account and could not find a location to order a new sim card! So no, I'm not happy with the results on this issue!
When in the chat ask for a live agent.
