โ07-26-2023 04:49 PM
I just transferred my phone to Visible. I am unable to make or receive calls, am I missing a step?
When should I be able to use my phone for calling out. I am only able to send & receive Texts.
โ07-27-2023 05:19 AM
I assume you activated using the Visible app. Restart your phone after activation.
โ10-14-2023 02:40 PM
Ikent3256, were you able to get your phone working? I have the same problem
โ10-14-2023 02:46 PM
Ikent, Have you solved your problem. I'm going through the same thing.
