International Prepaid SIM Card
megaubrey01
Hello!
I am traveling to Italy and Greece at the end of the month. I have an iPhone 8 on Visible. I'm looking at different options to be able to use my phone there. I'm looking into international prepaid SIM cards. They're a little confusing. They say I have to contact my provider to unlock my phone to use it. Has anyone ever done it? Can it be done with Visisble? Just don't want to purchase it and then not be able to use it and be scrambling over there.
Thanks in advance for your help!
Megan
jth
Hello megaubrey01,
Did you get the SIM card to work out for your travels in Italy and Greece? I have the same need as you did and would benefit from your experience πŸ™‚ Thx!
