Iphone 14 plus $199 deal with visible plus pro year subscription
micheleoh
I want to get this deal it says available to new and existing members but I can't figure out how to get it. If iI add the phone to my cart and then try to add the plan it directs me to my account to change plans. When I do this it removes the phone from my cart. What is the process to get this deal as an existing member
4 REPLIES 4
Here are the instructions from the deals page:
  1. New members join Visible on the Visible+ Pro annual plan; Current members update to Visible+ Pro annual plan
  2. Select Apple iPhone 14 Plus (128GB) device for purchase
  3. Enter promo code SWEETDEAL on the My Bag screen, and complete checkout
  4. Activate service on the device
If that doesn't work then you would need to contact customer service and ask them to fix it or add it to your account.
micheleoh
Unfortunately Didn’t work for me. Spent several hours with customer service trying to get this deal to work for me. So frustrated I gave up. Looking for new service because I need a new phone.
shafferl
Is this a brand new phone or refurbished? Thanks
Ladyjintexas
I have the exact same issue. As a current customer, I upgraded to Visible + Pro - and the system said it would be active on June 12, 2025.  Then I went to deals and found the correct iPhone 14 Plus - and it says code sweetdeal not eligible.  Chatted and spoke with customer service to find out the service has to be in effect - and they couldn't change that - and if I wait until 06/12 the deal will no longer be available.
But they said I was free to buy it at full price... so helpful.
