Solved: Is visible able to assist in unlocking the bootloa... - Visible Community
Is visible able to assist in unlocking the bootloader of a samsung device?
69
I have a samsung note 20 5g and I'm just wondering if there is anything that visible can do on their end to help me achieve bootloader unlock. Samsung by default won't allow you to unlock the bootloader even when you buy the phone outright. ๐Ÿ˜•
Hey there! Thank you for your question, at this time Visible is unable to unlock devices via bootloader. -JN
snappyapple632
Visible won't be able to help you unlock Samsung's bootloader. If you want to root your phone I'd suggest buying from a brand that does not have bootloader protections.
Samsung devices sold in the US cannot be officially bootloader unlocked. I have seen some workaround/hacks, but I would not recommend doing that as they are very YMMV.
