Kyocera dura force ultra 5g u w
Henry180
My employer who supplies my phone is switching to visible.  my current phone is old and will not work so I have to upgrade.  trouble is I need a military grade phone and visible does not offer one.  My question is, does anyone know for sure if the Dura Force Ultra 5G UW phone that is offered by Verizon is compatible with the visible network.  Thanks
With Visible the only way to know if it is compatible is with the IMEI number of the phone and run it through the compatibility checker. Visible has no list of compatible phones and their IMEI database is kind of sketchy. Also, buying a locked phone from Verizon won't work on Visible, it needs to be unlocked.
My suggestion is to pick a major brand like iPhone, Samsung, Pixel or even a Motorola and get a durable case for it such as the Spigen Tough Armor or something similar.
