β11-16-2022 04:17 PM
Hi, I have my mobile network with Lyca and I would like to avail port in promotion for buying iPhone 14 pro. But, Lyca was not listed in eligible carrier. Please confirm the same.
β11-16-2022 04:55 PM
You would need to get a hold of customer service. No support techs monitor these forums as it is peer to peer. Here is the link for acceptable port in's https://www.visible.com/help/port-in-promotions
Lyca is not on it so I really don't think you would quailfy.
β11-17-2022 03:46 PM
If your provider is not on the list then you are not eligible.
β11-25-2022 06:20 PM
Did you find any alternatives?
