โ07-17-2022 03:36 AM
The
on the Motorola site show the internal storage at 256G and 8G of ram. The Verizon Visible site shows their phone as having only 128G of internal storage. Is this a mistake or did Visible have the storage size decreased since 128G is not an option on the Motorola site. If the internal storage has actually been decreased to 128G what other specs have been changed internally on this phone? Is the Ram 8G or has that been modified too by Visible?
โ07-17-2022 04:59 AM
Often the phones sold by carrier have different (and lower) specs than those sold directly unlocked.
โ07-17-2022 08:44 AM
Yea but the Motorola carrier phone is a better deal and has more colors....plus Visible is still not supporting the unlocked Moto G Stylus 5G 2022 even though they are basically selling it on their phone deals page...I doubt there is any difference internally in the functionality of the two phones.
โ07-18-2022 11:56 PM
You could always buy the phone from Motorola, and before opening the box, run the IMEI checker on the Visible site to see if it will work with the service.
โ03-21-2023 06:36 PM
I did buy one and Visible checker says not compatible. It is compatible with Verizon and all Verizon MVNO's so why won't it work with Visible?
โ09-26-2022 09:42 AM
Anyone ever find out if ordering direct from Motorola worked or not?
โ09-27-2022 09:36 AM
Just an FYI...
I did order an unlock phone directly from Motorola.
https://www.motorola.com/us/smartphones-moto-g-stylus-5g-gen-2/p?skuId=777
So far, it seems to be working fine with Visible.
โ03-21-2023 09:17 AM
I ordered this phone (Moto G Stylus 5g 2022) from Motorola. Motorola website said it was fully compatible (5G, hotspot, wifi calling) with Visible. Put in Visible Sim Card in... everything was fine 5G, hotspot, etc... except wifi calling. I could turn on wifi calling in settings, but when I tried to make a call using wifi calling it reported I needed to connect to a wifi network. I did a speed test using chrome and saw that I was connected to my home wifi with a speed of 250 mbps... I have tried to do wifi calling using other networks (work, a fiends house, etc) and I continue to get this error.
Plugging in my old Google Fi sim card (still active), it immediately allows me to use wifi calling. I also tried a firends Verizon sim card and it too worked flawlessly. So, it's not the phone.
Visible tech support continues to run me through the same steps (factory reset, reset network, power cycling phone... etc). It's been a week and they can't get it to run wifi calling. As I get little to no cell coverage at home and at work, I need wifi calling.
Has anyone else tried this phone on Visible and found wifi is enabled but won't actually make a wifi call? If so, were you able to get Visible to fix the problem? I am tired of being run through the same steps over and over....
โ03-27-2023 09:16 AM
UPDATE: Visible Customer Support has continued to escalate my case every time I contact them and I re-explain my situation to the new chat representative including the fact that I have tried everything that is in their script. At this point, the representative escalates my case and tells me I will get an email in 24 hours. Email arrives the next day saying problem is fixed, which it never is. When I contact back, my case has already been closed. Who runs customer support this way? How can you close a case if you have not confirmed it has been fixed? This caused me to spend another 1/2 hour when re-contacting the chat to explain what has happened and what has been done so far. Overall, I spent over 15 hours in chat with customer service going around and AROUND....
I have signed up for and tried another MVNO running on Verizon's Network, which runs at about the same price as Visible (I think it's $5 more a month). It works on my cell... wifi calling, hotspot, 5G, etc. So, I guess at this point, being a week and a half in without Visible being able to help me,I will be porting out to the other service and leaving visible. ๐ I didn't want it to end this way, but it is what it is. Hopefully Visible will fix their customer service procedures.
Good luck everyone!
