Moving number over from Verizon to Vision
ChrisV
Vision's form is not accepting my account number or port out PIN from Verizon.  Verizon says the numbers are accurate, and the problem is on Vision's end.  What do I do?
peterson123
I am also having the same issue. Was using Verizon prepaid and Visible just can't recognize my account # at all. Visible customer rep couldn't help either. Sigh
