10-28-2025 10:36 AM
My brother recently passed away. Our family would like to gain access to his phone and eventually terminate his contract. The Visible chatbot was unable to assist, as a code was needed to access a human assistant that can only be generated by the on-network phone. Any advice on this issue would be greatly appreciated.
10-28-2025 12:37 PM - edited 10-28-2025 12:41 PM
Unfortuantely, this is only a customer to customer forum and no Visible employees actively participate here.
You might want to try the X or Facebook contact options shown at:
https://www.visible.com/help/contact-us
If you have a Reddit account, they also offer some support over in the Visible subreddit:
https://www.reddit.com/r/Visible/
or compose a message to them at https://www.reddit.com/message/compose/?to=VisibleCareSupport
FWIW, Visible is a prepaid service so if you can somehow disable his payment method (creedit card etc) they'll cancel the account for non-payment.
10-28-2025 02:07 PM
Thanks so much, this was very helpful.
10-28-2025 02:05 PM - edited 10-28-2025 02:08 PM
Will try the Reddit option.
