Need help with activation and Rogan Discount
tstive
I am currently using the 15 day trial. I want to go ahead and activate the Visible+ plan. I want to use the Joe Rogan code to save $5. How do I do that. And I think I saw that the plan was good for 24 months or 30 months, can't remember. Can you clarify.
That code is not listed on the deals page at visible.com so it may not work. You would be better off using the current deal listed on Visible which is code 35PLUS that will get you the plus plan for $35 a month instead of $45 and it has no end date. You can also save another $20 off your first month by grabbing a referral code from the savings spot in this community forum, that will also give the person a credit for the same amount. To enter the the promo and the referral codes there are separate boxes at checkout, make sure and put the right code in the correct box and they both should apply, the codes are case sensitive so make sure to type the code exactly how it appears. Your first month should be charged at $15 once activated and then it will be $35 per month after for second month and beyond for as long as you are with Visible or until Visible decides to remove the promo with notification from your account which likely won't be for a few years, you can leave at any time since it is prepaid. If you change your plan to the base plan at any time you would lose the promo and you would not get it back if you upgrade back to plus.
