Newly actived Iphone 14 can't make calls [call failed]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
โ04-04-2023 09:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ04-04-2023 04:24 PM
@MjayB - Are you still not able to make calls? If not, can you check in your settings to see if you have a phone number associated with your device? Check cellular services to make sure all is copasetic. If you have a physical SIM Card, resetting your cellular services might also fix your issue. Same is true for eSIM, just be sure when you reset cellular services to not delete your eSIM.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ04-06-2023 05:34 PM
I would chat in with Customer service. They are very responsive it has improved from the past. This is something that should be easily fixed.
