No incoming calls
dfandrews44
I'm a new customer and having serious buyers remorse.  I can not receive incoming calls at all. They go immediately to VM.  I waited on line for a chat with Stephanie for 45 minutes.  When she came on she said she would send me a link to click on to my phone.  I never got the link and I never heard from Stephanie again.  Three hours later I'm still on line with her but get no response.  Even though all calls go to voice mail I'm not getting the voice mail message.  Nothing.
I want to cancel my service!!!
12 REPLIES 12
GreenSub
Are you an Android user and which plan do you have, older $25, new $30, or new $45 plan?
SIM or eSIM?
Sim
GreenSub
If you are also an Android user, have you looked at the APN settings? I have these notes (but am an iPhone user)
APN name: Verizon 2
APN: vzwinternet
MMS port: 80
MCC: 311
MNC: 480
Apn protocol: iPv4/iPv6
Apn roaming protocol: iPv4/iPv6
APN type: default,supl,mms
Leave all other fields blank, and save this configuration.
Restart the phone
I’m an iPhone user
GreenSub
Have you called another phone with caller ID and verified the phone number being used by your phone?
  • My number comes up.
GreenSub
I’m at a loss. I’ll assume “Do Not Disturb” is not enabled and when someone leaves a voice mail you can retrieve it on your iPhone.
Good luck and let us know if they fix it.
DND is off and I never get the vm
GreenSub
Have you done a *73 to stop call forwarding?
dfandrews44
iPhone 11. $30
If you want to cancel your service you can port out your number
Did you do basic troubleshooting steps? Restart phone, reset network settings,
