Non-phone connection
rpanson
Is it possible to use a Cudy P5 5G router to connect to Visible?
4 REPLIES 4
rjniles
Visible is a wireless carrier, not an ISP
What function does a wireless hotspot provide?
SIM cards from Visible are meant to be used in a smart phone and not a router/hotspot, it goes against Visible's terms of service to be used in that way. Your phone can serve as a hotspot but it is limited to 5Mbps and 1 device(although Android phones can bypass this limit but still limited to sharing the 5Mbps)
rpanson
Thank you for the information.
