β11-08-2022 09:15 AM
I purchased a new iPhone 14 Pro from Visible to replace my iPhone 7. I went through the process of transferring the info and then proceeded to the Visible app on the new phone. I always get to the point of sending the code via SMS to my Visible mobile number and it never comes through to my old phone. I have tested texting and it works fine on wifi. I have been on at least three Visible chat support sessions. The sessions probably added up to four hours. I have been happy with Visible and the straight forward business strategy but this experience has got me so frustrated that I am about to switch to T-Mobile.
Has anyone else had this problem? Any idea what could be causing the verification not to come through?
β11-11-2022 09:16 PM - edited β11-11-2022 09:25 PM
Hello @swoopusa
From reading your post it sounds like you no longer have service on your iPhone 7.
If you are sending text messages over Wi-Fi and they are Blue you are using iMessage, this feature does not need a cellular plan.
If you are using the new iPhone verify you are logged into the Mail app with the same email your visible account has on-file. Go into the Visible Mobile app press (account) and check under your name.
β11-13-2022 04:08 AM
Thanks for responding to my cry for help. I am still using my iPhone 7 with no issues. The problem is I cannot activate my new iPhone 14Pro. It is connected to wifi and yes I can receive text messages via iMessage. Its been a week and I have tried everything and I never receive the one-time code via SMS to my Visible mobile number. Suggesting's?
β11-13-2022 05:49 AM
βConnected to Wi-Fi and you can receive text messages via iMessage.β
The one-time code you are expecting to receive is automated from visible, it is not going to be received as an iMessage.
You can use the iPhone 7 without issues:
β11-13-2022 06:14 AM
Hi domG,
Yes I can make calls and receive text without wifi on my iPhone 7. I just tested it with an android user. I also tried to activate the new phone again with no results.
Thanks for the suggestion anyway.
β11-13-2022 06:40 AM
If you have not already tried:
Ask support for a brand new eSim.
Support will ask for the new phones IMEI. Dial *#06# on the iPhone 14 and the info will come up.
Use a desktop/laptop if you can, just donβt use the iPhone 14 if you use live chat in case you have to reset it during the process (I had my own issue and I chatted via Facebook messenger, the response time is slower but I didnβt have to worry about walking away from my computer and missing the queue on the live chat or getting disconnected.)
After thinking about your issue. You have an iPhone 7 with a physical sim and you need to transfer that as an eSim to the iPhone 14 because it does not support the physical sim
Support needs to give you a completely new sim. Still verify you didnβt lose service on the iPhone 7 (sim number disconnected) if you have to receive sms verification.
β11-13-2022 06:50 AM
Been on the pc chat support for hours and we have tried everything you mentioned. They even convinced me to upgrade to the new $30 service and sent a new physical sim for the iPhone 7. The weird thing is I am not receiving emails from Visible support. The emails come through as messages to my iphone to verify my email. I checked with them and they are sending it to the correct email. They are are not going to junk or spam. They finally gave me a case number and said that the internal tech team was working on it. That was three days ago.
I do appreciate your input and willingness to help.
β11-13-2022 11:10 AM
I am not able to receive an email from them so I cant even port out to another carrier. Should I try to edit my email in my profile?
β11-13-2022 01:01 PM - edited β11-16-2022 11:50 AM
You would have to wait 30 days to get that email. The fine print under edit profile:
βIf you recently updated your email, weβll continue to send emails of a sensitive nature to your old email address for 30 days. Once your email has been in our system for 30 days, we will begin sending all emails to your new address.β
Have you possibly changed your email in the past 30 days?
Also check these solutions out:
https://community.visible.com/t5/Need-help/Confirmation-Email-No-joy/m-p/362#M369
β11-18-2022 09:01 AM
The exact same thing is happening to me now. I canβt get the verification code from Visible. I also have been on fb messenger for hours and they have now expedited it higher up. Did you get a resolution?
β11-18-2022 09:05 AM
The same thing has been happening to me. I canβt receive the 4 digit code to set my new phone from visible. Iβve been on fb messenger too for hours and they have now expedited it higher up. Did you ever get a resolution?
β11-29-2022 03:33 PM - edited β11-29-2022 03:35 PM
I am having a very similar issue. Was this ever resolved or did you switch service providers?
β12-08-2022 09:06 AM
No. I have been on vacation using Whats App on the new phone. I just got back and I am having the same issue with not receiving the text verification code on my old phone. So far my new phone was great taking photos and videos. π
β12-19-2022 07:01 AM
Update - I received an email stating that they have have fixed my email issue. I thought great, I got an email so it must be fixed. When trying to log into my account it doesn't recognize my email login. @#%! So, now I cant login into my Visible account, I cant use my new Visible iPhone 14pro, I am not receiving txt/sms or email verifications. I can only use my old phone that that cant transfer over due to the problem of not being able to verify it via sms or email. At this point I just want to leave Visible but I would like to keep my number that I have had for over 20 years. This is terrible!
