โ07-26-2025 10:09 PM
So this is a long shot, but it doesn't hurt to ask. I was doing a bunch of cleaning and I found my OG Motorola Razr, the old dumbphone, from Cingular and was wondering if its at all possible to use it on modern networks still. Could I chuck a SIM from Visible in there and she'll be right? I'm shocked how well its kept over the years. Powers up and all but the battery is cooked, that's an easy replacement though. Gave it a mild alcohol wipe down and the finish came back a treat. I just think it would be cool to get the old girl working again if I can.
Thanks for any help
โ07-29-2025 04:08 AM
Will not work. The network technology used today did not exist back in that era.
