OnePlus 13
dmg76
Anyone know if the OnePlus 13 is compatible with Visible’s network and all features on the Visible+ plan? And as a side note, is there a way to check phone compatibility without entering a device IMEI, as in just at the basic device level?
There have been reports on Visible's Reddit page that people have been using that phone on their network.
No, there is no other way to check compatibility other than the IMEI checker. I don't remember of those that are using it already had an active pSIM or not. I know there were reports that when the phone first came out Visible's IMEI database wasn't updated with the numbers, can't say for if it is still.
