06-27-2025 06:06 AM
I activated Global Pass before heading on my trip. I even got a text from visibile recognizing that I was outside the US. After a bunch of things, including chatting with an agent, my phone works only for calls. I cannot text or use any apps, like Uber, and no internet searches. I’ve tried a huge variety of things. I have an iPhone12. Many of the suggestions talk about turning on “roaming” but I don’t see that anywhere. My son is with me and he is frustrated too. Any help is greatly appreciated as I cruise around europe. Thanks
07-05-2025 09:45 AM
For iPhone, you turn on Roaming in the Settings -> Cellular -> Cellular Data Options section.
It sounds like you don’t have access to a cellular data plan wherever you are. If your phone works it means your voice service is allowed to roam. That “should” also allow SMS/RCS text messaging to work as well. See my suggestion above to turn on roaming for the Data service.
08-23-2025 06:55 PM
On my iphone 15, the Data Roaming option is in a different place. After trouble shooting with support for a while, I found that mine is under Settings>Cellular>eSIMs>Primary, and then Data Roaming is an on/off toggle.
Oddly my wife has the same phone and same Visible plan, and it's in the place that everyone else seems to reference (Settings>Cellular). Hope this helps others!
